5.42 testers needed!
Hi all! We’re working two new exciting things: A new Centroid profile based on 5.42 (their latest release) and we have a new backup and restore utility that makes moving profiles WAY easier than it used to be.
If anyone out there is interested in testing post here and I’ll get you setup. I’d love to see some ATC, and some non ATC folks on this test.
So, who’s interested?
This is the link to the testing forum
If this link doesn’t work for you it means you haven’t been added yet. Post here and I can add you. For those that have tested in the past this link may work already.
Yes!!
hit the link in the first post, it should work for you now
I’ll test it once I get my ATC set up
You don’t need an ATC to test, a non ATC test would be helpful too :slight_smile:
I’ll give it a go!
You should be good to access it!
Sweet, I can do some testing while I assemble my ATC. Can you add me to the forum?
You’re added!
Hey @NLE you interested in testing?
I am in.
Hit the link in the top post here. You’re white listed!
I would like to give it a go - getting ready to make some halloween tombstones.
-scott
You’re good to go to use the link in the first post here
I could test also – at a good point between major projects
You have been added! Look at the first post for instructions
Eric:
I’d like to be part of the test. The ATC has been working very well since you had me tweak a couple of settings.
Thank you.
You’re in, hit the link in the first post and you’ll be taken to the download area
Thanks. Turns out I lied slightly as I have one project to finish than I can test. BTW, I’m a non-ATC (at the moment) tester.
