Centroid Feature Request / Issues
Hey Greg, this one was a bit of a needle in a haystack, but I think I solved it. It will require a new post (which I will attach below)
This issue was isolated to only files with 4th axis work in it.
Make sure you have your post set like this:
It should be noted that you CANNOT use rotary with anything other than G53 safe retracts, but you CAN use it with a “no move” at the end.
And for some additional clarity:
The “no move” at end means that FUSION will not issue a move command at the end. Our M30 script WILL do a move command at the end of a job. No matter what it will always to a G53 Z0 home.
It will move to XY home if you have that set in the wizard.
Avid CNC EX Router V2.cps (77.2 KB)
Try this post to see how it works
