Home Position of Z axis on EXT
Just finished an EXT conversion and the Z axis value only works, if i set it to +0, -14.5 in the wizard. (I have an extended range z axis.)
This then doesn’t work after i set work coordinate as it gives me z axis over travel.
I then go into the wizard and change the axis limits to +14.5, 0. and when it homes it sets its position to 0.75 at max travel.
How do i set my home position to be 14, or 14.5" after homing. I cant find a custom setting in the wizard even when i click the check box to use custom values it doesn’t let me change where the Z axis after a homing
Don’t mess with the min/max travel limits in the wizard. Put those back to where they should be for your axis configuration.
I think where you are getting confused is that you’re trying to set Z zero, you need to change to a tool first so the tool can be measured:
Thank you, it was a bit of this, and also a bit of not hitting F10… a coworker may have killed our touch plate, I have a new one orderd, so i was doing it all manually.
