This is correct, you can do it:
Should you? Probably not. You have to cut at about 5-10 IPM. You risk creating a lot of smoke or a fire cutting like that.
You should use the spindle for cutting wood that thick.
Check this post for laser feeds and speeds: Laser Feed and Speed Chart
