I’ve been playing with the plywood setting on both 3mm and 6mm Baltic Birch… they didn’t even come close to cutting through (we’re talking a 0.5mm depth at most). What’s the best way to trouble shoot this?
For reference, I triple checked that everything was correctly set to mm/s, and I’m using the 45w laser calibrated with the 21mm cube.
On a 45 watt laser that should be no problem. Not sure why you switched to mm/s. You don’t need to, you can use the imperial speeds that are in that chart.
Regardless make sure your laser is properly focused on top of your material, when your laser is deployed (you can manually do this in the laser utilities menu) and you jog it down to Z zero your 21mm block should fit snugly between your material and the body of the laser (NOT the nozzle)
also make sure the power switch on the laser is set to “II” and not “I” that switch reduces the power by 50%
You did it correct (this is just for the calibration) when you actually setting up a job you use your spindle to set XYZ to the material and then switch to the laser
It’s a physical switch right on the front of the 45W laser. 15 watt doesn’t have it
Ok, and if you’re on power level II (2) then we’re looking at a few things: The switch is as far right as it goes (towards II). Image attached. It that normal or is it getting blocked?
Dirty lens… A lens that’s blocked by smoke or a lens that is dirty can seriously hinder performance. The laser is brand new
Are you running air assist? And is it strong enough to push smoke away? Yes, lots of air flowing out the bottom of the laser, zero smoke visible
Have you checked your lens to see if it’s dirty? The laser is brand new
How are you creating your G code (what program) and can you post it here v-carve pro. attached
I = half of the diodes on the laser are being used II = all of the diodes on the laser are being used (full power)
Soot can get on the lens in seconds especially if you don’t use the air assist
Smoke, even if there for a split second can obscure the laser light. You really need to make sure you’re properly mitigating it. And to be clear on air assist: There’s a fan that pushes air down, and there is also air from your air compressor that is controlled from a flow valve on the laser mount plate. The latter is what actually keeps the smoke away from your cut and the dirt off of the lens.
I would need to see your G code to actually determine if there any problems, but from what I can see from your picture you are cutting at high power, but you are cutting way out of focus. The diameter of that laser beam is .007" and what I am seeing there looks to be .125", so that tells me that your laser is cutting really high, which is why you’re not seeing the cutting performance you expect.
Sorry, I missed your G code in that earlier post. Took a look and the G code is fine, you have your Z zero set right and your power level is 100%
The laser bean is cone shaped, that’s why getting the laser the correct height above the surface of the material is key (think of using a magnifying glass to focus like to make a fire)
At it’s smallest the beam is .007"
What I am seeing is that your beam width is a lot wider and that’s due to you either cutting too hight or too low.
Triple check this:
Go to UTILS, Diode Laser, Deploy Laser (laser will drop down)
if you drive your machine over top of the material you’re intending to cut and move it down until your DRO reads Z zero does that 21mm block fit right under the laser BODY (NOT the nozzle)
Just like this. If it does than your Z zero and your laser calibration is correct.
Also check: when your laser deploys are you positive it’s coming all the way down on the deployment? If you push it downwards can it go any farther?
Again, it looks like you’re cutting way to high here which is why you’re not seeing any cutting performance. Solving for that incorrect height is what we’re trying to do here. Either either a setup issue or a calibration issue.
ok, I just did that… I set the z to zero, then ran the deploy command…. z automatically went up to 5.3417… then the laser deployed… same height above as before
