Auto touch off through G code
I am posting this in case it will help anyone else. I was bothered by the tedium of touching off every tool after a spoilboard surface. So I wrote a quick g code file to touch off all tools. I know that Centroid will do it as its running a job for every tool that is zero. I just wanted to know that all of my tools were touched off before running jobs. Not the most exciting thing, but it helps me.
This works on my set up (Avid EX with RM70C spindle) If it doesn’t work for you use the same concept in your G code editor. Be careful and have your finger on the E stop until its vetted.
Auto tool touch off.txt (219 Bytes)
G17
G20
G80
G90
G53 Z0
G90 G0 X54.0000 Y100.0000
T1 M6
M5
T2 M6
M5
T3 M6
M5
T4 M6
M5
T5 M6
M5
T6 M6
M5
T7 M6
M5
T8 M6
M5
T9 M6
M5
T10 M6
M5
T11 M6
M5
T12 M6
M5
T13 M6
M5
T14 M6
M5
M30
Make sure your tool diameter is set under the maximum size so you don’t have to intervene with the pop up. I am using a CNC depot spindle with Corbin’s macros, so I am not sure if this functionality is in the new Avid spindle package. If not it would be a cool feature to add to the VCP. My old SCM machine had a menu that you can choose the tools you wanted to touch off and just hit cycle start. I have a rack with 14 tools and I surface the spoilboard after about 20 sheets or so. so this makes sense for me. If you use this, edit the park position and number of tools to suit your set up.
