Brand new Pro 2x4 for sale
I decided to get a 24R and get out of this. Fully built, unused CNC table. Comes with computer, everything to get you running. The router is a Dewalt 611 and obviously is not one of the higher end spindles that can be used with this machine. That is because I was going to get a CNC Depot ATC spindle setup, but my plans changed to just keep it in the family and do a Tormach 24R, which can be seen in the background.
There is absolutely nothing wrong with it because it is brand new, under power and can demo. I have the original receipt for it and paid just over $12,000. With the included computer, control station, registered Mach 4, we are looking at a total cost probably around $13,500. Looking to get $8000.
I am willing to deliver if within a reasonable distance of NJ. Cost to deliver is flat $300 plus 95 cents per mile including return distance home. Would be delivered in a box truck with liftgate. If you are serious, this is a great product ready to use once delivered.
Machine Specifications:
Work Area:
X: 49-1/2" (1257 mm)
Y: 24" (609 mm)
Z: 8" (203 mm) or 12" (304 mm) - minus spoil board thickness
Footprint:
Width: 67" (1700 mm)
Length: 40-3/4" (1100 mm)
Height:
77-1/2" (1970 mm)
Weight:
340 lbs (154 kg)
Cutting Speed:
500 IPM (NEMA 34 version)
Rapid Speed:
1000 IPM (NEMA 34 version)
Drive System:
X/Y: PRO Rack and Pinion
Z: Precision Ballscrew
Resolution:
X/Y: 0.0005" (0.0127 mm)
Z: 0.0002" (0.005 mm)
Repeatability: +/- 0.002" (0.05 mm)
Accuracy: +/- 0.005" (0.127 mm) or better
Hello, is the machine still available? I’m located in NJ.
