Has anyone experienced their CNC12 / EX controlled machine periodically not homing identically / loss of repeatability?
I was running a rotary job when the bit stalled in the material. I stopped the job (via tool check, then cancel). Re-homed the machine just to be sure, as the bit had stalled the gantry. Went back to work X0Y0 and found it was 3/16" off in -X.
Turned off the machine completely. Turned it back on and re-homed it. Gave the same result.
Oddly enough, it also seemed like the machine itself - not just its work X0Y0 - was off. My tool height setter is on the front right corner, and I had to specifically increase the x-travel to feel comfortable that a 1/2" diameter bit would not collide with the spoilboard during a tool height check. After this stall, it seemed (I can only perceive as I never measured it before), that the spindle was also off (-X) from where it was previously, as a 1/2" endmill nearly collided with the spoilboard.
Now I had a custom WCS angle loaded the whole time (the rotary-recalled WCS). Don’t know if that had anything to do with it, or if rotary WCS’s need to be cleared every time the machine is turned on and homed.
-Matt
