For Sale: Avid PRO4896 4' x 8' CNC Router - New Never Run (Everett, WA)
Brand New Avid CNC PRO package
Water-cooled S30C Spindle
6 Tool Automatic Tool Changer
Selling my complete Avid CNC PRO package. It was purchased Brand new and never commissioned. The CNC has never cut a part and has never been powered up for production.
Why I’m selling, honestly: I bought this to add sheet-goods capacity to my wood production shop. I wanted to do a full vacuum table and kept reworking the design. Originally, I had wanted to build this CNC in an upright vertical position, and have also purchased the steel for building a strong steel base (CAD Drawing below). Originally I had started with a 4’x6’ (none-standard setup), which is how it is currently assembled. Then I changed my mind and purchased the necessary parts to make it a standard 4x8 CNC. CAD Drawing of a 4’x8’ size. Meanwhile the demand for CNC work grew faster than I could get this machine built. I ran out of runway, needed capacity now, and ended up buying a ShopSaber CNC before I could finish assembling this one to my speck. So it’s a complete package sitting in my shop with nowhere to go, while it could be running in someone else’s. New buyer decides to complete my original plan or just buy the legs for this CNC Machine from Avid.
What’s included
Avid CNC
  • PRO4872 4’ x 6’ CNC Router Kit — NEMA 34 1/2" shaft compatible, 8" Z-axis travel / 8" gantry height, standard gantry width
  • Plug and Play NEMA 34 CNC Control System — (1) 20’ and (3) 26’ cables (the 4’x8’ / 5’x10’ cable configuration), 4-drive standard
  • PRO Linear 4x6 Extrusion Bundle
  • Pepperl + Fuchs Proximity Sensor Kit — PRO CNC configuration for machines larger than 5’ x 5’
  • 3 HP / 4 HP Spindle Tramming Mount
  • Auto Z and Corner Finding Touch Plate
  • Mach4 CNC Control Software
  • PRO CNC Machine Spare Parts Bundle (NEMA 34)
  • CNC Router Bit Set
4’ x 8’ extension parts
Purchased to lengthen the machine from 4x6 to a full 4x8 footprint:
  • 2 x 4080 Extrusion, 3050mm
  • 1 x GH20 Linear Rail, 3050mm
  • 2 x PRO Gear Rack, 39" (1 meter), with T-nuts and button head cap screws
  • 1 x Gear rack splice piece
  • 1 x 20mm Linear Rail Fasteners, 2 rails, 48" travel
  • 1 x 75mm x 25mm Cable Track, 1 meter
CNC Depot S30 Turnkey ATC Spindle Package
  • S30C spindle - ISO30 taper, ceramic bearings, 24,000 RPM capable, water cooled
  • Turnkey spindle control box with vector VFD, relay-controlled pneumatic solenoids, air pressure monitoring, and the 14-pin bulkhead connector that plugs into the Avid control box
  • 6 tool Holders each with ISO30 ER32 tool holder, ER32 collets, Delrin tool fork, and tightening fixture
Bonus, included :
Condition
  • Never run, never cut a part, never used in production.
  • Mostly assembled.
  • Stored indoors in a heated, dry shop the entire time.
  • The ATC spindle package is open and has never been mounted, never powered.
Location & Pickup Everett, WA 98204 — at my business off Hwy 99, straight shot from I-5, 25 minutes north of Seattle. I have a forklift on site and will load it onto your truck or trailer.
Feel Free to call or text. Serious Buyers only, please.
(425) 350-5630
Sale Price: $12,000
