I’ve been diving into macros as a first time user of this code and have found it super interesting (and difficult).
I do a lot of slab furniture work and often times, I need to plot points for locations of cracks that I need to patch. I have been doing this manually - jogging the machine to the crack, writing down the X,Y coordinates, and plot several points in my CAD file to manually probe the location of the crack.
Ideally, I could set up one of the macro keys on my WMPG-6 (Pro5x10/EX/Centroid/CNC12) to write the current X,Y position and create a list in Notepad++. I would take that list into Rhino/Grasshopper where I would plot the points at once.
Looking around the forum, I had found an interesting thread regarding custom macros, and found it to be a great intro into how these codes work.
I thought I had found a possible solution from this thread. There is an existing macro in the “\cncm\system” folder named “probe_write_point_to_file” and I used that to rewrite “wmpgmacro4” in my macros folder for my user profile. Code below:
; Filename: probe_write_point_to_file.cnc
; Purpose: Write a point to the currently open data file
; Programmer: John Popovich
; Date: Nov 9, 2010
; Usage: G65 “/cncm/system/probe_write_point_to_file.cnc” X[x_position] Y[y_position] Z[z_position] D[skip_new_line]
; Where: x_position = x point
; y_position = y point
; z_position = z point
; skip_new_line = 1 to skip the new line
; Notes: A file must be open for output
; Copyright (C) 2011 Centroid Corporation, Howard, PA 16841
if [#24901] then M223 "%c %f " #20101#24
if [#24902] then M223 "%c %f " #20102#25
if [#24903] then M223 "%c %f " #20103#26
if [#24904] then M223 "%c %f " #20104#5044
if [#24905] then M223 "%c %f " #20105#5045
if [#d != 1] then m223 “\n”
The macro won’t run when I have my machine on and notepad open. Is this something that will only run with a probe attached? Or am I going about this in the completely wrong way?
I have greatly appreciated all the knowledge in this forum - super inspiring!
I would like to have a macro also like you describe
I had a program I ran with Mach 4 that recorded the position to a file each time I pressed the enter button on the keyboard. I could then upload that file to Vcarve and it would plot the vectors defined by the points.
I did a little research and was thinking about trying the:
You’re on the write track here… You can open a data file and you can write the current machine position out to a file. That’s a classic digitizing workflow.
You can use something like G code ripper to take your digitized moves and turn them into DXFs that you can bring back into your CAM tool
Does the code above rely on a probing macro to initiate? Or is this type of code able to run from the home screen when I hit the WPMG button assigned to this code? I’m having trouble deciphering the workflow in the code.
Ok @NLE I finally circled back to this and have it worked out.
I use the WMPG-6 controller for my machine (Pro5x10/EX/Centroid/CNC12). I’m using the “Macro4” button to write coordinates to a .txt file.
I modified “wmpgmacro4” under the “\cncm\system” folder to read below:
In order for this to work, I created a .txt file named “XY Coordinate Probing.txt” and listed the file location after M121.
This text file needs to be open when recording the points. I open this file in Notepad++ and Monitoring “tailing” needs to be activated (located under View>Monitoring (tail - f).
M122 writes the X,Y,Z position to the open text file and every subsequent press of Macro4 will record the new X,Y,Z position on the line below.
I then “save-as” this file as the probing record, and clear all the data from the “XY Coordinate Probing.txt” for the next time that I need the file.
