I’ve got a couple of rotary projects that need to be free of tearout and chatter. One is a wooden spoon that vibrates a lot (duh, it’s a long thin stick between centers
and the other is a more beefy spindle. For non-rotary jobs I’d switch between right- and left- turning bits as needed to avoid splintering at corners, but for rotary? I normally use a up-spiral round nose bit for carvings but I’m afraid any bit of flex would cause an up-spiral to grab and splinter or chatter. Down-spiral round nose bits are rare, but I’m thinking a down-spiral doing climb-cut only parallel to the axis would be safest, if it cuts cleanly at the tip. For the spoon, though, I think it might be better to do rotary cuts from the tailstock to the chuck to maximize support.
Have any of you gone down this rabbit hole already? Any advise would be handy ![]()
