Probably not but you loose tramming ability in a hard bolt with alignment pins. Chances are it would not be parallel to the work surface. Large VMC’s have a mounting base plate that has lateral movement in the X axis and shim the Y axis. The mounting bolts are large and allot of them. They generally have to check the tram after a collision or spindle replacement not heavy machining.
Brad257
21
Related topics
| Topic | Replies | Views | Activity | |
Spindle Tramming
32 | 2448 | May 27, 2025 | |
Manually squaring the gantry's "resting position"
31 | 1760 | January 19, 2023 | |
Z Moving Plate Out of Square
26 | 294 | July 1, 2026 | |
Conceptual GD&T Spindle Setup. Set it and forget it! Use tramming as a FINAL CHECK ONLY!
7 | 273 | June 22, 2025 | |
Circle problems. Thoughts?
40 | 1377 | November 22, 2022 |
