Is there anyway to manually edit the height offset column in the tool library?
Reason: When doing inlays I want to surface the plug .002 above the worksurface, can not figure out how to do that with vcarve so I thought I would ask about the tool library.
That’s best done manipulating your Z offset in the Set Part Zeros>WCS CSR table. You can add or subtract to your Z offset. Practice by pressing the ABS/INC button in that menu and typing in +1 or -1 in a z offset to see what it does.
