Avid 4X8 with 4th axis Brand New used 6 times to cut foam
Avid 4X2 with 4th axis Brand New used 6 times to cut foam 254-722-1879 McKinney TX
1 PRO4824 4’ x 2’ CNC Router Kit - Version: Nema 23 3/8" Shaft Compatible - Z-Axis Travel / Gantry Height: 8" / 8" - Gantry Width: Standard
Leg Kit (PRO CNC) - Size: 4’ x 2’
Plug and Play NEMA 23 CNC Control System *- Cable configuration: (1) 12’ and (3) 20’ cables [recommended for 4’x’2’, 4’x4’, or 5’x5’ machines] (+$21.00) - Motor Shaft Diameter: 3/8" (Low Inductance 420 oz-in) - Additional Motor Drive: +1 [5th-Drive Upgrade]
Pepperl + Fuchs Proximity Sensor Kit - Sensor Configuration: PRO CNC (5’ x 5’ machines and smaller
HP Plug and Play Spindle / VFD System - Compatibility Option: CRP800 (Standard
3 HP / 4 HP Spindle Tramming Mount
ER20 Collet and Nut Set, Imperial
Auto Z and Corner Finding Touch Plate
Mach4 CNC Control Software
CNC Router Bit Set
PRO CNC Machine Spare Parts Bundle (NEMA 23
Avid CNC Rotary Axis - Electronics Option: NEMA 23 Plug & Play
