Thanks for the reply, same metal dust as seen in a few other threads here.
Seems this is normal according to those threads, but just seeing if anyone actually solved their issue outside of lithium grease (seems to be the fix people use).
Suspect the gantry is off kilter but it could be the motor mount as well.
Ideally we have the guy out there who can say yeah tighten screw xyz on xyz part and should be good. And if not, I will try to return with an answer.
I’ve had this before as well - though mine was rubber (not metal), and was fixed with replacing the motor pulley and sprocket. Double check the height of the sprocket on shaft - if that is off it makes the belt spin off-axis resulting in that sort of dust.
Never do an offset strategy for a finishing pass on 2.5D carves, always do raster. You will always get that diagonal with offset no matter how good the machine is.
That dust is normal if its not lubed, but you have a lot so take it apart and see if the gears are excessively worn, or do a backlash test.
Lubing the gears helps prolong the life. I use a dry lube spray on the rack gear every once in a while. Grease tends to be messy.
