Camera probe for Avid
I’ve been working the past few years on a Mach 4 and Centroid compatible visual system for Avid. Works like a camera probe with a calibrated camera that closely maps what it sees to coordinates on your work surface. From there you can store useful positions, capture part geometry, then export DXF to CAD, or use built-in CAM to cut.
Here’s a video showing how to navigate by clicking in the camera view, find circle centers, cut what you see:
The website is at https://feachr.it
I’ve been mainly dealing with factory automation eg inspection processes for PCB manufacturing, but I’d like to hear what projects where it would help you.
To get people thinking about possibilities, I would like to have this to replace my probe and touceplate:
  • Setting X-Y center of features (squares, circles, between edges, etc.)
  • Corner finding
  • Bonus, find Z height
  • Setting the location to drill or cut a mortise on an existing part that I don’t have CAD for, or the workpiece is large and unusually shaped (like dropping a butterfly on a large slab crack)
  • Setting the X,Y, Z offset from the optically probed point to one of my lasers or my spindle (i.e. a library of user created offsets for different cutting tools that can be applied with a push of a button).
  • Mapping and converting to vector file different features or objects. Anyone working with live edge slabs can appreciate this.
  • Capturing the position of an odd shapped workpiece and aligning the CAD to it
  • Would be cool to be able to mark the bounds of an object. For example, I layout a mortise on a chair leg in pencil, then I mark the corners or line edges with the camera to define the boundary and then I tell it what bit I’m using and how deep to cut and it cuts the mortise for me.
Basically anything a physical probe can do, but you can also align it with crosshairs on the camera image so you can also you unprobable features like a pencil mark. Whats cool about this is you don’t have to install or adjust a probe, and then probe, and then remove the probe again, etc. you can just turn it on and do everything from the computer.
You should also be able to use it for squaring the gantry. It should be able to look at a known picture/item, and move around looking at the picture from different positions to know if the machine is square, and how much it needs to be adjusted.
Speaking of looking at things from different positions you should be able to generate models using photogrammetry. Though this will be hampered by no forth axis on the camera.
I used a camera on Mach 3 as a corner finder, and as a way to tell if my board was aligned on the axis. On Avid Ex I don’t really care about the alignment because I can use the WCS angle. Calculating that would be useful.
I see value in being able to set the Centroid coordinate system rotation (CSR) using the camera to identify the locations. Could be useful for avoiding flaws in wood or other times ultra precision isn’t needed to establish a good CSR.
You can both position and rotate GCode that you bring with the “GCode Operation”. You’ll see the bounding box of the gcode in the camera view and can move and rotate it. This will wrap your code with add a G52 that includes the camera offset from the tool and a g68/69 that rotates your gcode as you did in the camera view.
Cool!
This chat has mostly focused on probing, detecting, alignment. I wanted to take a sec and show the cutting side of things since I introduced visual CAM operations. If you’re starting with GCode or just an SVG, you can quick go from vectors to cuts. The twist is you’ll see where the cut aligns, say you’re engraving, making inlays or just want to actually see what’s gonna happen. You can also aircut first and send output gcode to your machine to use graphing operations there. In short, I’m trying to close in on a very tight understanding of what you’re going to get before you put tool to material.
Here’s an example starting from an SVG file and using Slot operations with a v-bit to engrave and a cutter to remove, note the tabs too.
That would be an awesome addition. It could also be used as a “Howyadoing?” check for stepper motor machines to check for lost steps.
New video showing geometry tracing. Let’s say you have an existing part, or heck just a piece of material and you want to chamfer an edge, enlarge a hole, trace a some geometry and bring it into your own CAD. I’m making a set of these “fundamentals” videos where I really show you what I’m getting at with the whole “vision-first CNC” idea.
I know, not everyone will immediately be a convert, we’ve all built our own hard-won processes. But in my own work anyway when I’m doing prototyping or building the actual Feachrcam cameras I sell, I’m up and cutting faster and I have more confidence I know what’s going to happen when I run the job. Sometimes I do drop back to Fusion, Vectric etc, I export to DXF then use that in a model and generate GCode. But then again I’m back in feachr.it to bound that gcode, align with my part and do the cut.
Here’s the video:
I love the features, though there are many that are nice but not needed, but as a hobbyist it is priced far more than I would be willing to spend.
You can now align parts, set your coordinate system rotation, and position cuts with feachr tags. Hope this helps those who don’t enjoy using ruby probes and corner finders!
I wanted to share an overview of how to get maximum accuracy and repeatability with the FeachCam. It’s pretty satisfying to click on the corner of a part, zero your WCS, move away then click again and come back to within 0.002". Really it’s not that hard, you map the camera with a printed sheet of paper, drill a small hole and detect it with the camera. Then wherever you click, that’s where you go. This tolerance is good enough for many applications in wood and metal, but not everything. The camera isn’t a ruby probe, but those are a bit cumbersome. I’m hoping to bring back the speed and joy of “measure and mark” but with the added juice that CNC machinery add to our world of precision part fabrication. Enjoy!
These days I’m really just trying to get people used to the idea that CNC isn’t always about modeling in CAD then doing CAM then export GCode, then go to your machine. The process can actually be more like your manual tools: mark, measure, cut. This little calibrated camera and a dollup of good user interface is what makes it really fast.
If you’ve been curious, and want to get started, this video shows the basics.
After you get your camera mounted and mapped to your machine, here’s what’s next: how to trace parts and see what you’re about to cut. In this one, I’m taking you through making your first Feachr, a simple Point. Then we move on to tracing circles: let’s say you want to bore a hole that’s just undersized—trace the circle to get its current size and position then add a Bore operation.
I also show how to trace corners, which is really useful even if you just want to go set your Coordinate System Rotation (CSR), you want to easily find the orientation in degrees of your part relative to your machine. But you can also make cuts parallel to edges: let’s say a dovetail joint for woodworking, or a chamfer on a part you just plunked down on the table. Don’t line it up, tell your machine to line it up.
And working in this visual world, you can create a Text feachr, then use it for an Engraving operation—you cut what you see, so it’s easy and pretty fun to position directly say from a mark on your material.
Hello hello it’s that time of year and I’m no exception so I’ll do a 40% off camera deal through Monday. If you’ve been curious about Feachr.it, the website has new project ideas and videos, there’s a new documentation website and I think I may have ticked all of @jjneeb 's ideas up there. He’s kept me busy!
I think the biggest one not mentioned on this thread is measuring object height. I’m now mapping the camera in full 3d. You just put a feachr tag on your material and the camera will measure its depth then automatically raise an equal distance above your base height.
@PaulC I use the Corner detector all the time to get angles for WCS. I clipped this video so you can see how to measure and place Corner Feachrs: https://www.youtube.com/watch?v=pGeuxiTa1po&t=862s
I see the pricing for the cameras. Is the software included with the camera purchase or is it a separate purchase/subscription?
@docrawfo Yes the software is included in the price of the camera. You don’t have to pay subscription fees with the current promotion. I added pricing knowledge to the AI chat on the website too.
