Basically, I would like to make a temporary change to the length of my 60120 by at least 3 or 5 feet, more if need be, without having to cut anything, and be able to later bring it back to its 60120 size. Has anyone done this, or is it even possible?
A 5x10 is typically two 5x5s with a few minor adjustments. I think they’ve only changed a little over the years. At worst you might have to adjust where a pair of legs attaches to the segment you’re keeping. And then move the sensors and sensor flags or whatever was attached at the back end of the full 10’ length.
Thank you. I had looked for splits in the pieces and had thought not everything had them, but I think I see them all now. I will download the build plans for my series and look over them. I appreciate your input.
