Turnkey Acorn CNC control
Wired and ready to mount on your Avis CNC Router or other Router Frame
The Control will be prewired and configured for you New or Retrofit machine.
This is a 4 Axis System ready to be attached to your CNC Router mill or lathe comes complete with all wiring, Servos and control cabinet. Add you your CNC from and you could be cutting in a few hours. Optional inverter drive can be wired. and set up for your spindle motor.
Features:
- State of the Are Acorn by Centroid CNC Control.
- High Quality Servo motors and drives (3)
- Pre-wired CNC control panel set up for 3 Axis Router or 750W . (other sizes available and additional
axis setup available) - Nema Control Cabinet
- Windows 10 Computer with software pre-loaded and set up.
- Servos are pre-wired and ready to mount to your machine.
- Spindle contactor provided, and inverter drive can be added to the system.
- I have Router and mill spindles available.
- This system uses Servos not steppers.
- Controls available to be shown under power on Routers and Mills subject to stock on hand
- ATC is an Option and can be added to this existing Control
The Centroid Acorn is the best of the best in the latest DYI controls. The software and features that Centroid offers are second to none. Cutter comp, Back lash and a user group that is robust and ready to help.
The hard part is done for you with this turnkey system. It is a professional wired panel; the system will ship fully assembled all you will have to do is mount the motors to your machine set the soft limits and with the hard limits if used. (instructions and breakout terminals provided.)
All Mill systems are pre-wired for 4 Axis so a rotary can be added. If used on a Gantry an additional motor and drive will be needed. If used on a lathe a motor and drive will be removed. But the wiring harness will be set up for 4 Axis and the Centroid Control can be configured for Lathe, Mill, Router or Plasma.
This listing is for a Turnkey 3 Axis Avis Type Router. Please message for other configurations. With my system you can have your new or retrofitted Router running and making parts in hours. Remote set up and support available. Spend time making parts and not trying to wire controls.
The pictures above show Panel being bench tested additional pictures will be added soon. You Tube video being prepared and your system will be bench tested and a video recorded prior to shipping. Controls are in stock subject to previous orders Delivery Is 48 Hours and 30 days for non-stock control built to order.
Centroid supports standard G&M code has a robust support network and can configured to run most mills, lathes, routers and soon Plasma and Flame cutters.
