EX / fusion speed change
A bit of annoying change from Mach to ex / cnc12. When I have two operations one with one speed say roughing and another op right after with same tool say a finishing pass where the speed changes, it stops and asks me to verify tool is about to start. This is just an annoying tidbit since if I am across the shop and I have a 20 minute job running and at 16min it stops I have to run over and continue. It should not stop and await user input if the tool is the same tool and speed is just changing, just pause change speed and continue.
Tim
Which specific message is coming up when this happens?
I think It says something about the spindle is about to start. Even though the spindle is still spinning.
You can turn that off in the warnings in the wizard.
