HELP! I don't know what to do
I have an AvidCNC Pro 48x96, and I am running Mach 4. Everything has been great but suddenly I have a problem.
When I home the machine, the Machine stops and the error line says that the motor is having trouble backing off the limit switch. I switched to the diagnostic tab and everything looks good. However, the Y axis keeps both indicators lit. I don’t know where to look to fix the issue. I don’t know if it is a Mach 4 issue or a motor/hardware problem, so any advice would be appreciated.
The machine was running fine this morning but suddenly after a reboot it has gone goofy, Anybody have a clue where to point me for help?
Mach4 has this “feature” where it likes to corrupt the configuration file (AKA Machine.ini located in C:\Mach4Hobby\Profiles\AvidCNC). Whenever someone says it worked fine until I rebooted or restarted Mach4 or something like that, but you didn’t make any changes to software or have some kind of other event (like you backed your F150 into your machine), then I suggest restoring the Machine.ini file with one in the backup.
So close Mach4 first. Then you can rename your Machine.ini (just in case you want to restore the current one), then go into C:\Mach4Hobby\Profiles\AvidCNC\Backups and copy the most recent Machine.ini.xx file from a date and time that you know the machine worked correctly. This file is created each time Mach4 is started.
Paste that file up one directory in C:\Mach4Hobby\Profiles\AvidCNC, and delete the .xx from it so that it is just named Machine.ini. Then restart Mach4 and see if it is now working.
I’m on it, Thanks!
Okay, tried that without success. I also reinstalled the Mach 4 software, again no success in repairing the problem.
Here is the log from Mach 4:
ESS: Mach4 Enabled
ESS: Homing started for Axis 2
Home switch Z Home tripped!
Limit switch Z ++ tripped!
ESS: Switching to HOMING_AFTER_BACKOFF_MOVE state.
ESS: Homing of axis and final move completed successfully
ESS: Homing started for Axis 0
ESS: Homing started for Axis 1
Limit switch Y – tripped!
Home switch Y Home tripped!
Home switch X Home tripped!
Limit switch X – tripped!
!!!WARNING: A motor seems to be stuck backing off of a home
switch! Check the diagnostics tab to see if the Home switch indicator
is active when the switch is not!
I think you should get in touch with support. You can use the link right at the top of the page here.
I did, thanks!
I sent them an email and a message through the website. So far, no response. Might be on vacation or something. Doesn’t speak well of their support staff.
We were shorthanded last week, I was actually jumping in to help out too. They will get back to you.
I understand! Everyone has personnel issues on occasion! Thank you!
Is there any way to home the machine without using the home button on the software? I am in the middle of a project and cannot finish it. If there is any way to set a home position manually, rather and letting the machine do it, I might get back up and running on this project. I am sorry that I don’t know the answer, but I haven’t downloaded the proper documentation yet. I wish that there was a location to download all the manuals for the entire machine, as I print them and put them in binders for future reference.
You can set the machine to home in place, however your home position won’t be accurate.
To set that you go to Configure>Control>Homing:
Hey folks, just thought I would bring you up to speed. First, thank Avid’s help dept. Their suggestion fixed it up!
The gears that drive the rack and pinion system were worn. When trying to home the machine, it would get to the point of setting off the sensors and then try to back up a very small amount. It wasn’t able to back enough off of the sensor due to slop in the worn gear(s). I replaced all three gears sets and belts on the X and Y axis and it works perfectly. Just in case anyone has the same issues.
Love that line..“Feature” ..we say that in my job (software dev) all the time..not a bug..a feature
@Mikesibley Thank you for posting this issue…very helpful. I am encountering the same problem. After contacting support today, I was advised to pursue a different troubleshooting path that may involve replacing one of the controller boards.
Coincidentally, I had already ordered a replacement set of gears last week after observing noticeable wear. I am cautiously optimistic that installing the new gears may help resolve the issue, but I will report back with results once the replacement has been tested.
