How to minimize Cnc12 screens?
Hello is there a way to minimize Cnc12 screens?
Sometimes I need to access items on the desktop.
Tnx!
No, unfortunately not. You can hit the windows key (between control and Alt) and the D key at the same time and it will bring up the desktop with all apps minimized.
However, the CNC12 screen has an annoying tendency to keep poping back up on top.
will cycle through open screens. That’s what I typically do when I want to go back between programs. Or… two screens will change your life.
Well that didn’t work “” “, ”
Alt Tab
By design CNC12 is supposed to be the only thing running when you’re using the machine. This is why it doesn’t easily let you minimize it
We don’t recommend using the PC for anything else other than running CNC12 to control the machine.
So you may be able to find some workarounds to get to other programs but we don’t recommend this.
There is a minimized button in the upper right corner of the profile manager
On the same pc as Cnc12 one usually I think would run vcarve and a cad. So I did but these on the taskbar for quick access.
But sometimes I need to do somethings on the desktop as well.
