Coming to Mach4 from CommandCNC I am still kind of confused as to how to set the initial z zero height before I hit the start button. With command CNC the ohmic sensor or the backup switch just figures it out and sets the z zero height correctly when you hit the home zero button. It seems from what Ive seen in the AVID getting started videos the verbal instructions are to just get the torch tip within less than a quarter of an inch from the top of the material and call that z zero then let warp9 try to straighten it out when it does the initial touch off. When I do that it seems to work, but it just seems wierd to me for it to work that way. My AVID Mach4 router uses a touch plate which is more like the way it works for me in CommandCNC on another plasma table, except once you select z home then the torch just touches the work then calculates the torch height distance and then retracts .15 from their to the pierce height called out in the g code in order to begin the cutting process. I think it then recaulates a new z zero prior to each pierce, but I could be wrong on that part? Any advise would be appriciated.
