Has anyone integrated Lightburn to the centroid controller - are there any special G-Code scripts etc and is it straight forward?
Lightburn does not support the centroid controllers. It can be used to generate Gcode for them though. Its pretty straightforward.
Thanks, Is your lightburn preference file the latest you recommend.
Yes, I haven’t made any changes for 6 months. I have been busy lately and not a lot of playing with the the lasers.
This is my current configuration: https://drive.google.com/file/d/1Q0Rkh8FLA5zMC_4QIjwVVs_qaY7lStG1/view?usp=drive_link
jim
Many thanks. I have found Vectric limiting re laser test paterns for calibrating output and also photocarve. Lightburn seems to have a lot more in these areas to offer.
You are correct. LIghtburn has a lot more in the way of test patterns built in. I still end up making my own most of the time because I am looking for specific things. However, LightBurn gives you control of things like the pixel width, and it makes a more accurate vector file than Vectric does.
For basic graphics, I like Vectric just because its the tool I use for all my spindle work too, so I can integrate everything. However, for detailed picture images, Lightburn is much better.
