Lines using moulding toolpath
Hi. I’m using aspire to carve a frame using the moulding toolpath. on my y moves I am getting some lines in the carve that aren’t there on the x moves
Here is a picture. it’s the lines going the same directions as the arrow I drew. It kind of seems like chatter but the x move areas are smooth. what would be some stuff for me to check? would a bad bearing block do this? Thank you.
Looks like your travel height is too low. You are dragging the tool across your workpiece. But I don’t use that aspire thingy…
Wait, are you talking about the thin lines running left to right that the drawn arrow is touching? Or in the groove?
I recently did a project where minimizing these lines was key. I have two observations that might help:
  1. Tram your spindle! If it only happens in one axis (X motion vs Y motion), it’s likely your spindle is tilted a bit in the other axis (i.e. if motions along Y cause lines, you’re tilted in X - the tilt is perpendicular to the motion). I ended up building a tramming tool for mine and found it “nodded” forward quite a bit.
  2. Inspect the lines under a microscope. I found that climb vs conventional cutting caused a different type of tear-out in the underlying wood pores, as well as the different feet-per-minute tool speed for the different sides of the bit. You might need to change your toolpaths to be less than 50% overlap and only one direction.
The other thing I thought of trying, but didn’t, was to use a bit that had a radius at the tip instead of a sharp corner. I thought the sharp tip was scratching the underlying wood, but it turned out that the above two options fixed it well enough. I also made sure my toolpaths ran in the same direction as the grain, to help hide what lines remained.
By this I mean, most metalworking end mills have a small radius, like 0.010 inch, instead of a sharp 90 degree corner like woodworking router bits have, at the outer edge of the tip of the cutting surfaces.
:rofl:
A picture is worth a thousand words. A picture with a line hand drawn on it is 2,000 words…
@djdelorie is probably right.
I’m talking about the lines you can barely see running the same direction as the arrow line. i know what the line the arrow is pointing to is. sorry i didn’t mean to be confusing.
I did tram it using this tool. i don’t believe that is my problem.
Edge Pro Tram System with Calibration Gage & Padded Case, 1/2" Shank Size, 0.001" Graduation - 01-000 - Penn Tool Co., Inc
Your next step is “inspect under microscope” and find out what’s causing the lines to be… well, lines. In my case, it was a tear-out problem.
Figured it out. Had just a hair of play on the right side of my gantry. found a few of the bearing block screws that were under stuff loose. seems good to go now. I guess no more getting in a hurry when re tightening things. I know I should have looked there sooner. last time I looked for stuff to retighten I didn’t want to re set my square sensors so didn’t take it all apart. Lesson learned.
