Under; configuration, control, motors. What motors are what? Motors 0, 1, 2 3 4. I was looking at the acceleration and direction and I see motor 0 is checked reverse, all others are not checked.
In the configuration screen there is another tab that will tell you what each motor is labeled as.
One will be x, one for z and 2 for y axis.
The one that has the reverse box checked will be one of your y axis as you have 2 motors and 1 will drive in reverse.
The reverse motor would be the Y slave! Of course. Thanks, I’ll take another look and see if I can figure the rest out.
Hey Nick, I took another look in the configuration and under axis mapping I found X is 0, Y’s are 1 and 3 and Z is 2. Under motors, motor 0 is the one that is reversed,  so it’s the X axis that is reversed; not the Y slave?! Hmmm, I’ll have to think a little more about that one.
Steve
I think it’s X/Y/Z/Slave/A just like the motor drivers in the PnP box
