Good Afternoon,
I found a project I would really like to attempt but I need input on several aspects of this project.
Project Summary:
I watch a video where a pistol slide was customized with some CNC cuts and what not. I have the same Pistol and would like to attempt this myself. I will post a YouTube link to the video that’s 10 minutes long. This video will show what im trying to accomplish.
***My First question at this point: Do you think the PRO4896 with 4HP HITECO spindle is ridged enough to attempt this project? My PRO4896 is basically a toy so I can take extremely shallow depth of cut’s and run for 2 days continuous if need be. I’m not limited on time because of customer projects…
***If the consensus is the machine is ridged enough then I’ll need to identify some tooling. I’m thinking I could do this project using 2 tools. A ballnose and Endmill that’s specifically for steel. I’m not sure which 2 tools would be the best so suggestions are welcome. If you would like to make a suggest please include the Amana part number. 100% of the time I use Amana bits that I purchase from ToolsToday.com
***Brainstorming options for a vice to hold the pistol slide for this process. My Avid machine is used for woodworking projects 98% of the time. I have played with a couple blocks of 7075 Aluminum before so… I’m going to look at some amazon workholding devices since this will probably be a 1 time project. I don’t want to drop hundreds on a work holding vice for 1 project.
For now I’ll stop here and see what information is posted then on to the next step.
Here is the link to the YouTube video.
