New problems with CNC12
I am encountering new problems with CNC12. I have had multiple instances of my machine diving into my spoilboard for no reason when the depth has been set to 0. It will stutter and then dive. Also i am trying to run a job in the middle of my machine to flatten a part of my spoilboard and in the middle of the job, the machine stops so I rehome and then try again. I dont know why it is stopping. When i try to resume the Z goes down and as the machine tries to go back on the Y axis, it stutters and stop. I have reports generated from CNC12 but i dont know what they mean. Any help is appreciated.
Hey Chad, I think it’s best you get a support ticket going (use the contact link above)
Sounds like you might have a couple of simple things that need to be worked through
Hi Eric! I tried working through things and see if i could get it worked out. Undortunately that didnt happen. I have emailed Support anf hopefully they can get back to me soon and get this resolved.
Taking a bit of a shot in the dark here… but are you running G code in one unit and your machine in another?
For example: Your machine is set to inches but the code you’re running is in MM?
Not that I am aware of. I could share a g-code file of a recent project if you want to take a look.
