Rapid speed changes
I am running a 96 x 60 AVID pro with Nema 34 steppers. I notice that my rapid speed changed to a much slower rate when a adjusted the feed speed of a hole i was cutting using the pocket command. I was cutting a series of 3/8" dia. holes using a 1/4" compression bit in MDF. I notice that a couple of the holes looked a little elongated in the y- direction. My feed rate was set to 200 ipm using a Whiteside bit. I thought maybe that the feed rate was too high for the small diameter, so I changed it to 80 ipm. When i did this i notice that the rapid feed between hole was about 80 ipm also. Where or how do I set or change the rapid feed rate in CNC12. I thought the rapid rate is independant of the feed rate for cutting.
Thanks,
Tom
Your rapid feed rate between cuts is set in you CAM software.
