Special Thanks to Corbin Dunn-EX Upgrade
Greetings all,
I just wanted to give a special shout out and much gratitude to @corbin for his work modifying the CNC12 software to work with our ATC setups! Without this, I wouldn’t have been able to get the EX upgrade until Avid finished their ATC option. His ATC is the Hiteco, mine is the CNCdepot S30C. I just ordered the EX so I’m not sure yet if I’ll need to make any tweaks yet, if so, then they’d be very minor.
I was using his feature rich Mach4 screenset up until now and had come to strictly rely on it. When I was notified that he made the switch, installed the upgrade, and modified the software, I immediately ordered the awesome EX upgrade.
If the same scenario is holding you back then you no longer need to wait and you can get your EX upgrade now. Here’s the link for his Centroid CNC12 mod.
[GitHub - corbinstreehouse/Centroid-ATC-ToolRackSetup: Macros and an application to manage an ATC tool rack for Centroid CNC12 and Avid CNC.]
Thanks a million Corbin!
Awesome, that’s great to hear! I’m sure you’ll like CNC12/Centroid - it is definitely more rock solid than Mach 4. The main UI is a little more simplistic, but it does all the basic stuff.
The API (Application Programming Interface) is more complex for Centroid, and allows one to build a traditional windows application using .NET, but doesn’t have a lot of the pre-defined UI bits that Mach 4 had, so I had to write a lot of stuff from scratch. But this is more powerful, and I can do more stuff with it. I am thinking about doing a new skin for the entire UI at some point!
Corbin
Yep His software is working great! thanks Corbin!
