Surface spoil board - Calibrate Tool Height Setter again?
After initial setup and successful use of the tool height setter, does the calibrate process need to be run after every spoil board surfacing? Seems like yes, but wanted to confirm.
Ok, I see now that it isn’t necessary.
Should there ever be a situation to recalibrate?
The only time you’ll need to recalibrate your tool height offsetter is if you move it, or you move your Z axis prox sensor.
You will however need to recalibrate your spoilboard whenever you resurface it. There’s a utility for that in the UTILs menu from the main CNC12 screen. It’s very easy to do and takes just a minute.
