Hi All.
Avid CNC provides stepped 8mm rod for setting rotary table and probing.
Does anyone see a potential issue with using 0.25" precision rod?
Are you doing this on Mach or EX?
Mach4
Anything? I am assuming that you guys went in to trouble of stepped 8mm dowel for probing for some mathematical issue in the software but may be in the newer version 0.25" could be used to avoid extra collet change?
Sorry I missed this one, the answer is here:
https://www.avidcnc.com/support/instructions/rotary/usersGuide/#143
You can change the tool diameter to whatever you would like
Perfect, thank you.
would this matter on an EX system?
