Were do I find the explanation for these 3 mounting heights to determine what i should go with? I have a 4 HP plug and play spindle from AVID. Thank you!
My interpretation, it’s based on the height you installed the Cylinder Nose Bracket in a previous step. For a MTC spindle, like the 4hp, that would be the lowest group (by color).
Yes but you’ll lose a bunch of tool holders because you’ll need to space your tools out a lot more because the laser will hit the adjacent tool with that older deployment system
The Aux Box that came with the updated laser kit doesn’t have labels at most of the connection points. The instruction do a good job of explaining what goes where but I was still going to add my own labels for all the laser connections. Is it currently unlabeled because the aux box is intended to be so modular that the configuration could change down the road? I don’t want to make the labels overly permanent if they may change in the future.
I just received my aux box and laser deployment kit. The support site says the laser deployment instructions are coming soon. Based on the above, are there a draft set available?
