Aspire PostProcessor Line Numbering for EX controller
So I was running my first 2 hour carve on the ex controller, while everything went fine, I was trying to figure out where i was in the program and I noticed it said N320130 was the line, I looked in the source and that was in the first quarter of the file, and since this was already 1.5 hours into the run I was scratching my head. Then I noticed that after a N999990 it resets to 10 again and starts over, over 6 times in this file I was looking at. How can I actually tell the line number that is being executed if the N**** is all it shows and there are multiples of the same line. Is there a way to see the ture file line number? Also is there an elapased time showing somewhere, % completion, etc?
Thanks,
Tim
Open up the file in Notepad ++
I believe Centroid looks at the actual line number and not the ones generated by Aspire.
You can test this by resuming a file on a particular line to see how it works.
There is a timer on the screen for job time elapsed. There is no percentage done readout through.
