Avid centroid rotary and plasma?
Does the new system work with the rotary and plasma?
I have a project coming up and need to cut tube notches.
Tnx.
yes, but**
**When you’re using plasma there is a 4th port still open for the rotary axis. We (Avid) don’t turn it on because we don’t support that setup.
I don’t believe there’s any technical reason why you couldn’t do this. In CNC12 it’s as simple as just telling the control you have a rotary connected and configuring the steps per rev, etc.
The more challenging thing is going to be setting up the G Code files.
You might be better served by posting here:
https://centroidcncforum.com/viewforum.php?f=65
Got it…since I have it might as well use it.
I always wanted to have a longer gantry in install the rotary at the side of the machine…but I will look into this. Sheetcam does have the rotary option upgrade.
Tnx!
