Buying Pro 4896 -- Want to offload the Plasma elements
I am thinking of buying a new in box, but two years sitting, pro 4896. The issue is that it’s a bundle with a lot of Plasma elements. This could be a great deal, if someone out there is looking to get into plasma and will consider taking those off of my hands during the purchase. I’m in Colorado and I’d have to go about 300 miles down to NM to pick this up. Here’s the parts list:
-1 x Tramming GMT Spindle Mount
-1 x Pepperl + Fuchs Proximity Sensor Kit
Sensor Configuration PRO CNC (machines larger than 5’ x 5’)
1 x Auto Z and Corner Finding Touch Plate
1 x 2.2 kW Plug and Play Spindle / VFD System
Compatibility Option CRP800 (Standard)
-1 x PRO4896 4’ x 8’ CNC Router Kit
Gantry Width Standard
Version Nema 34 1/2" Shaft Compatible
Z-Axis Travel / Gantry Height 12" / 8"
-1 x Donek Drag Knife
Version D2
-1 x 4’ x 4’ PRO CNC Plasma Water Table
-1 x CNC Aluminum Cutting End Mill Set
-1 x PRO CNC Plasma Kit
Torch Height Control Plug & Play Electronics
-1 x CNC Router Bit Set
-1 x Leg Kit (PRO CNC) (CRP813-00)
Size 4’ x 8’
-1 x Plug and Play NEMA 34 CNC Control System (CRP800-00E-8)
Cable configuration (1) 20’ and (3) 28’ cables [recommended for 4’x8’ or 5’x10’ machines]
-Additional Motor Drive +1 [5th-Drive Upgrade]
You could search facebook marketplace to see the ad in Rio Rancho, NM
Funny, you must not have bought it because this is DEFINITELY the machine I just flew from Denver to Rio Rancho and drove back with on 5/29/2026! I guess he had it posted for a while?
Anyway, I don’t need the plasma components either and looking to sell them. Includes a “Plasma Kit” box (factory sealed) and the 4x4’ water table (New, still in factory crate). DM if interested!
