Can I digitize from paper template with cnc
I would like to make boat floor using EVA foam like seadeck. I have to make tamplate from the floor and somehow digitise it. is it possible to do the digitising with the cnc?
I’d ask @brettbond who runs Paper Tools
I’ll write more to you directly, but in short yes you can digitize large items with Paper Tools. The camera goes over the points you choose. You can export to an SVG file which you can use in Vectric, Fusion etc.
Here’s a video showing how all this works, against calipers to show accuracy:
I’m hearing a lot of people using Paper Tools for similar things: ā€œlive edgeā€ tables, modifying camper vans, guitar-making so I’ll continue adding more measurement features to see how far we can take it.
Sounds good I am interested
This is the video what I want to do
There’s another guy doing boat building by measurement with Paper Tools. I can ask him to connect with you if you want. Based on the video yes you should be able to use the measured points in Vectric to cut your foam.
I really appreciate your help
