Up for sale is a factory-fresh, genuine CNC Depot RM40C Automatic Tool Change (ATC) Spindle. This unit was acquired directly from surplus company inventory liquidation. It has spent its entire life safely stored in its protective plastic wrap and has zero runtime hours.
This is the premium “C” version, meaning it is factory-upgraded with high-precision ceramic bearingsdesigned for cooler operating temperatures, extended lifespan, and smooth performance at maximum RPM.
What is included:
- (1) Brand New CNC Depot RM40C Spindle Cartridge (as pictured)
- Please Note: This listing is for the standalone replacement spindle cartridge only. It does not include cables, pneumatic plumbing, tool holders, or the external VFD control cabinet.
Technical Specifications:
- Manufacturer: CNC Depot (Made in the USA)
- Model: RM40C (Ceramic Bearing Upgrade)
- Power Rating: 4 HP (Horsepower)
- Voltage Requirement: 220V High-Speed Induction Motor (13.5 Amps)
- Speed Range: 1,000 RPM up to 24,000 RPM (400Hz)
- Tool Taper: ISO30 (Pneumatic Drawbar for Automatic Tool Changing)
- Cooling: Integrated 24VDC Electric Cooling Fan
Compatibility:
This is a legendary, drop-in upgrade for heavy-duty CNC systems, most notably Avid CNC setups, as well as custom DIY or industrial routers.
Shipping & Handling:
Due to the high-precision nature of the internal ceramic bearings and the substantial weight of this unit, it will be double-boxed and heavily padded with foam/bubble wrap to ensure it arrives perfectly safe. Ships out fast.
Item is sold as-is with no manufacturer warranty implied, though it is guaranteed to be brand new and visually flawless upon arrival. Please review all photos carefully before purchasing.
