CNC DEPOT Users please read
Also, for reference, here’s my guide (based on Eric’s):
https://www.corbinstreehouse.com/blog/centroid-acorn-atc-hardware-setup-for-the-avid-cnc-ex-controller/
I would like access to the guide as well. Thanks.
DM sent
Anyone using these spindles know how much the draw-up/knock-out distance is on the draw bar? I’ve been running mine for a while now, and had to adjust my macro to slowly raise the spindle as it releases. Getting something around 0.100" to 0.128" Talking with a friend, he said that most spindles only have 0.010" to 0.015" or so, and he could adjust his spindle to reduce this amount.
I have an S30C and my code does a 0.125 move in coordination with turning the drawbar on/off to limit abuse of the toolrack.
@Eric Can you send me the guide please, thanks.
Done!
Can I get this info for the Cnc depot spindle
Eric, if you’d be kind enough to provide me with the documentation as well I’d appreciate it!
@Dallascww and @MichaelR check your DMs
Thank you sir!
Thank you
Hello @Eric I’ve just received my cnc depot spindle and avid ex control box. Can I get access to the guide you have reference above?
