CNC12 : How to extend soft limits
Hi,
My machine is not going totally to the back of the machine bed. I could use an extra 15mm at the back, and I would like to do so because I’m setting the rotary axis at the back.
How can I extend the soft limits of the machine on CNC12 ?
Thanks,
Nicolas
Look in the UTILs menu for an option called “travel limit setter”
This will detect where your homing switches are and set your travel limits accordingly.
You can also manually override your travel limits in the wizard.
Perfect, that’s exactly what I was looking for and it gave me the extra length I needed. Thanks @Eric
