Rotary Error Need Help
Working on making a column on the rotary. I have cut on it in the past so im not sure what has changed. I get the error “A axis commended over SoftMax”. What should the SoftMax be for the A axis? Should Soft limits be enabled on the A axis?
I don’t think soft limits should be enabled on an A axis. They aren’t on mine.
I ended up turning them off and was able to run the parts. Thanks
