Any thoughts on how to measure a diamond drag bit as the tip compress?
The spring rate on a diamond drag will surely exceed the spring rate of the tool height setter so you should be fine. You can also manually mesaure it in the UTILs menu bit I don’t think you’ll need to do that.
Worked great
Thanks Eric
