I’ve got a Hiteco spindle and i’m trying to use the same connector for the spindle wire.
Check this diagram:
Is that the same for the 6.5 kW spindle?
I believe all of our spindle cables are standardized around that spec. I pulled that off our product listing page for the 4hp. It looks like the 8.7 doesn’t have the connector diagram on it. You could contact support and they may be able to give it to you, or confirm that it’s the same as the 4hp.
I don’t want to say with 100% certainty because I don’t have both to compare.
That should be the same: https://www.cncdepot.net/product-page/s30-main-power-cable
It’s probably one of these: McMaster-Carr
Althougth I don’t know if it would fit in the body of the spindle, you’d have to check the measurements. You could also check Automation Direct which would likely have cheaper prices.
