First topo/laser result
After seeing others do this, I wanted to do it too for my own home town. I ended up learning all about GeoTIFF and OpenMaps to get the data, and custom software generated an STL I could import into FreeCAD for the milling, and a gcode file for the laser (the laser has to follow the topology, so a generic openmaps->laser conversion wouldn’t have worked)
As for why it’s so small… :slight_smile: I’ve “standardized” on 3x3 squares of wood for testing purposes, and have a vacuum jig on my table that holds them in place.
Sweet! Did you see the tutorial I did on those last year?
I’ve watched and read everything I could get my hands on, but I never have good luck running off-the-shelf software for these kinds of tasks. It’s partly because my PC is set up a little weird, and partly because what I need is usually a little different than what is offered. Plus I’m a software engineer and I like learning things :wink:
Eric, On this subject how is the laser nozzle height applied? I need on the XT8 for the nozzle to be .3 above the work surface, I went into wizard and set custom z offset to .3
but it is almost 1.75" above the work.
May I ask you to point us to that tutorial?
Thanks.
@Bstanga when you measure the laser with the tool height offsetter it adds the nozzle height to it.
Are you sure that’s the correct height for that 45 watt?
Are you talking about the laser setup tutorial?
Sorry my mistake - I thought the tutorial was about creating topo carvings and incorporating laser into the final project - thank you for the quick reply and have a great thanksgiving!
Scott
