Fusion Post Processor - WCS
@Eric - Does the AVID Post Processor for Fusion support WCS changes?
For instance, when I’m doing a 2 sided part I’ll have two setups in Fusion.
Setup 1 - Part in vise, WCS 54 set to top center of the part to machine
Setup 2 - Flip the part, WCS 55 set to parallel height for Z, stationary vise face for Y, reference pin for X
However when I post process setup 2, I don’t see Fusion changing the WCS in the actual file.
I can go in and manually change to G55 but was curious if this is something that can/should happen as part of the post processing?
Michael
Ah ha! Never mind, I found the answer in this post:
You can edit the machine setup to flip this feature on if you want to (machine setup in Fusion)
Yep :slight_smile: I found that yesterday after you kindly helped someone else out MONTHS ago :rofl: rtfm
