Hi all,
I’m new to the forum and to CNC in general. Been doing a lot of reading so far and plan to buy my first CNC after adding more space to my shop this summer.
I am a full-time cabinet maker. Work by myself. I mostly build office/living room built-ins and bookshelves. No kitchens. I’m not interested in the larger, more heavy duty machines that run closer to $50k - $100k. Hoping to find something used for $10k-$15k.
What I plan to use it for:
- Cutting one piece doors out of 3/4" MDF.
- Cutting out cabinet box or bookshelf parts complete with shelf pins, drawer slide holes, door hinge mounting plate holes, biscuit slots, etc.
That’s pretty much it. I have some other ideas of things I may try down the line, but mostly I just want it to do those two things and do them very accurately and without much work on my part.
If the machine had an ATC already set up that would be a perk as I would like to add that eventually to take full advantage of just setting and forgetting it.
This machine popped up on Facebook Marketplace recently and I was wondering what your thoughts were on the price and what it has for meeting my needs:
Thank you in advance as I feel a bit overwhelmed with all the wealth of information out there!
4’x8’ AVID CNC Fully Loaded PRO4896 (Elizabethtown)
Condition: excellent
Make / Manufacturer: AVID CNC
PRO4896 4’ x 8’ CNC (Fully assembled and working)
- Version: Nema 34 1/2" Shaft Compatible
- Z-Axis Travel / Gantry Height: 8" / 8"
- With Extended Wide Gantry (so you can operate 2 spindles, or spindle and plasma cutter, etc. on the same gantry)
Leg Kit (PRO CNC) (Installed)
Plug and Play NEMA 34 CNC Control System (installed)
- With long cable option, so you can add more length and width to the table in the future without rewiring.
- With additional 5th motor drive upgrade, so you can plug and play a rotary axis or additional Z-axis, etc.
Prox Kit - Pepperl + Fuchs Proximity Sensor Kit (installed)
2.2 kW Plug and Play Spindle / VFD System (included, not currently installed)
