Help, Spindle Cable length (kinda urgent)
Hi, I am currently laying out my new shop after my cross country move, (all my tools are in a c can in storage) I need to know the length of the spindle and vfd cord, I am laying out the new electrical and want to make sure it will work in the configuration that i currently have designed, and wont have access to my tools until electrical is all done. any measurements would be greatly appreciated.
Cheers
Harley
Chief sawdust maker at Stone Mountain Projects
It’s a 10-ft cable from the VFD box to the plug Hope this helps
And note that you can essentially put the control box on any corner of the machine, if your shop allows/requires it. The machine can be build mirror-image left-right to the instructions, and rotated 180 degrees. I suspect there’s a way to build it mirror-image front-back too (that would affect just the side cable chain, and maybe need different cables for fixed sensors), perhaps with a bit of hacking.
If you think you need something custom, the Avid support folks are fantastic at coming up with solutions.
What about the spindle cable?
Cheers
It’s a 10-ft cable I have a 5x5 machine the other one going to the spindle has an extra 10 ft of table as well what size is your machine?
