Wanted - 4hp Spindle/VFD Combo
I’m looking to purchase a spindle and VFD sometime in the next month or so. I’m most likely to choose the 4hp option, but I will consider others as well. I’m only looking for plug-and-play versions that match up with Avid / EX Controller. Also, if you happen to have a 15w laser and/or other lasers or just the deployment piece, please let me know. You can contact me directly via the inbox here on the forum.
I have that including the 15 watt laser I’m not using
Hey Brian - qq for you. I’m finally getting around to try out the spindle..lol. I’m getting a F1 code. It’s not currently hooked up to a avid controller. It’s just powered up. Any idea why that would be? Thanks buddy…Happy 4th of July!!
That box was running a 4hp spindle, non atc , I just googled and got the same overload explanation, I doubt it has anything to do with the 20amp breaker.
I think to be safe hook it up to controller and vfd. I would not know how to run it from vfd alone, but I don’t think you will hurt it , the setting may be different.
Sonds good..yup I get it…your use to just plugging everything in and
going..Thanks for getting back to me so fast..
