How do I save a post?
I can’t see anything on here that is equivalent to the “Save” command on sites like Youtube and Thingiverse. If that’s not possible here, can you please add some way for me to tag posts, so that I can easily return to them later?
At the moment, I’m having to save the bookmark in the browser, but that means I need to sync all my browsers across PCs, which is not something I want to do.
If it is possible, can you make it more obvious, please? Because I can’t see it!
Thanks,
Dan
Click on the three dots at the bottom right of a post and then on the bookmark.
Thank you for the suggestion. I tried it and it worked once. But now it’s disappeared again.
Also, the questions that it asks about “when do I want to be reminded?” appear assume that I want to read it at a fixed time later. So, perhaps it was designed as a temporary thing?
I want a way to refer back to the topic for an indeterminate amount of time.
Use Bookmarks and for the reminder just set “None needed”
To refer back to the post later just click your profile icon in the top right. That will expand a window that will have a link to bookmarks:
