Cut depths, feed speeds, and out side dimensions?
Im resurfacing My spoil board I made it a little bit too large and there’s Areas that weren’t touched at all…
All that should really be done in your CAM software and not Mach4. You can use the feed and spindle overrides to go faster or slower. You will need to modify the gcode in order to change depths and dimensions.
You can ‘tweak’ your cut depth in Mach4 by lying about your Z zero location. If you aren’t comfortable with doing that, it’s best to setup the CAM toolpaths instead.
