Issue with 4'x4' pro build
This is normal; welcome to the club :wink:
You have two options.
  1. Let the motors force the gantry into square with software, either by adjusting the sensor stops or by calibrating it out (I’m not familiar with mach3 enough to know if it has a setting for that; linuxcnc does)
  2. Shim the gantry into square, which means taking it partially apart. I had an old thread where I went through this, but in my case, a 0.006" shim on both ends took out most of the twist… You end up loosening the red vertical plates just enough to shim under one side or the other.
